I realize this has been a problem for a small subset of owners, and it should be addressed and repaired by Subaru.To develope to become the engine oil burner......
^^ This was one of the reasons I traded my 09 TDi Jetta in for my Forester. I also screwed up when I opted for their fantastic DSG over the 6 speed manual. The DSG's are great when they are under warranty and working correctly, however when they fail- you had better have around $6000 waiting to repair/replace them. I'll deal with the oil issue in the FB engine all day long if that's the worst I can expect from Subaru.
I have four relatives with 2011+ foresters and three of them have excessive oil consumption problems. I wouldn't even consider buying a new forester until SOA gets this issue figured out. I would almost rather have HG problems rather than the obvious piston ring issues these new engines have.I realize this has been a problem for a small subset of owners, and it should be addressed and repaired by Subaru.
I just hope this doesn't happen with the CVT!^^ This was one of the reasons I traded my 09 TDi Jetta in for my Forester. I also screwed up when I opted for their fantastic DSG over the 6 speed manual. The DSG's are great when they are under warranty and working correctly, however when they fail- you had better have around $6000 waiting to repair/replace them. I'll deal with the oil issue in the FB engine all day long if that's the worst I can expect from Subaru.
I agree. If Subaru wants to keep it's reputation with owners and potential Subaru buyers, Subaru should do the right thing, and make good with Subaru Owners with oil use issues.I realize this has been a problem for a small subset of owners, and it should be addressed and repaired by Subaru.
However, it's not as bad as the High Pressure Fuel Pump Failures of the Bosch CP4.1 found in VW/Audi Diesels, which have failed as much as about 5% of the time, spraying the entire fuel system with metal bits...costing 7,000-over 10,000 per vehicle (depending upon the vehicle) to replace the entire fuel system...pump, injectors, rail, bleed lines, fuel tank. So far, VW is repairing most of the affected cars, but, they die without warning, and, VW may quit repairing them without warning, too, as the complaint has been active for nearly 4 years, now.
I'd rather have a small subset with a ring hardness (or whatever the root cause is) problem, where I'll have to watch the oil level closely until it is repaired, instead of not knowing when my car will suddenly die on the road, and hope I don't get in a wreck when it dies, and hope VW will be gracious enough to fix my car...because there hasn't been an extended warranty offered by VW...just "goodwill repairs". Goodwill can evaporate without warning....that's why we traded our TDI for the Forester.
All mechanical devices have failures. Most can be addressed and repaired unless there is an underlying fault with the design. Based upon the vast majority of owners not complaining of oil burning, I doubt it's a general design problem...it's much more likely a particular part problem, such as rings that were too hard, or something along those lines. It should be fixable.
I disagree with the "rightfully" qualifier. A NEW engine is more likely to "use oil" for a while than an engine that has been fully run-in. In fact, I check the oil level on every new car/motorcycle I've ever bought, before leaving the lot, and immediately upon arriving home. Then, keep a closer-than-normal eye on it for the first thousand miles or so.I don't think most owners of new cars even bother to check oil in new cars between oil changes because they (rightfully) don't expect new cars to be losing oil, in which case, they wouldn't even be aware that oil loss was occurring.
That's fine. We can disagree on that.I disagree with the "rightfully" qualifier.
I see what you mean...the Average motorist isn't aware of the tendency for oil consumption to be higher during initial operation, so, they aren't checking it, so, more vehicles could be "using oil" than are being reported. That's logical.Most people aren't as painstaking as you are (or perhaps as I am); not even close as a matter of fact.
And that being the case, I think the claim that there is only a "small subset" of Subaru owners who are experiencing oil-consumption issues is questionable.
