Okay I did a Viofo A129 Duo install
1: Remove the speaker grill on the drivers side
2: Remove A-Pillar cover (Be careful of the tether, twist 90 degrees to release it from the A-Pillar Cover)
3: Route wires thru the headliner, down the A-Pillar, follow the factory wiring. I used zip ties to secure
4: Using add-a-fuse tap the front fog 12v positive 15a and ACC 12v switched 7.5a
5: Find a ground (I used where the lower air bag is attached 10mm)
6: Route rear camera cable thru the headliner to the back
7: Remove the upper hatch trim
8: There are two push pins holding the headliner in the rear. One on driver side and one on passenger side. You will need to release those to have room to access rear grommet
9: On passenger side release the rubber boot from the bigger grommet. you will see the white plug it is attached to
10: If you lift up on the white plug you will see the release tabs. Use a tool to release the grommet. makes it easier to put the boot back on.
11: Route your rear camera wire thru that hole.
12: release the upper rubber boot and release the white grommet
13: Route your cable thru the lower grommet, thru the boot to upper grommet
14: Route it thru upper hole and out where the factory wire exits
15: Reinstall the rubber boots onto the grommets and reinstall grommets
16: Hook up rear camera
17: Reinstall rear hatch trim
