So, I have a misfire in Cylinder #4, and the oil gets black VERY quickly after an oil change. So I'm guessing this points to bad piston rings allowing blow-by of combustion gases into the crankcase.
The misfire seems to go away around 2200 RPM.
Anyway, my question is, can I safely unplug the #4 injector to stop fuel being fed to that cylinder? Or will it trigger mad problems?
1999 Forester, Auto, 164,xxx miles.
Thanks!
Ivan
Thanks!
Ivan
