21 - 32 of 32 Posts
2015 2.5i Premium CVT
I've been looking at adding both an oil cooler (a few times I've hit 230 degrees) and a transmission cooler (just because). I just can't seem to find a good place to mount the coolers and not sure how well any of the sandwich place for the oil would fit with how our filters mount.
2016 Forester
On my recent trip out west pulling 1000lb camper with outside temp 100-109F, my dash display (triple meter) hit 255F a few times but mostly in 230-245 range. Also no trans cooler. Elevations as high as 8800ft. Temp light never came on.
2015 Forester CVT
Discussion Starter #24
I'm back after first tow
Picked up our Chalet LTW in Medford Oregon and brought it home to Eureka, CA. The dumbed down CVT in the 2.5 worked better than expected and gas mileage was down about 15% to 27.5. According to the sales slip, actual weight was 1,375 lbs.
Looking at things another way, brake pads are really cheap and easy to replace. OTOH I didn't need to brake any more than without the trailer. This is probably because I was going sensibly slower and my driving style is to maximize momentum. Still, I wish that the 2.5 had a better selection of CVT ratios and/or lockup modes for better deceleration, such as a "sport mode" or "mountain mode". I like the alliteration of the later.
GD
2015 Forester CVT
Discussion Starter #25
As for the Outback vs. Forester question: Looks like wheelbase is the difference.
GD
I'm a little late to your party guys and really appreciate all of the insights. So many things go into towing rating. I was going to buy the forrester, but ended up with the Outback because of the towing rating. Also because the Outback is a much nicer ride for a little more money.
My thinking on the towing is that connection between the drive train and the body could be a factor. Trailers hook on to the body, and the force from the trailer is transferred to the running gear. I don't know exactly what points take up the thrust, but all of the force from the driving gear has to be transmitted to the body through various engine, transmission and suspension mounts. These could easily be a big factor, and a hidden one for the towing differences.
Earlier someone said that the OP was obviously trying to tow above or at the towing rating because of his question, but for me, it was which car to buy. I don't want to tow my 900# teardrop with a 1500# rated vehicle. I would much prefer more headroom.
SeasonedStalker
2017 XT Touring in CBS HT CVT
I added the Hayden 679 trans cooler with a bypass install mounted passenger side in front of the radiator after seeing AT temp light a few times pulling passes fully loaded for a cross country road trip and have seen a 40 to 80 degree reduction in temps that I'm quite pleased with. Easy install as well.
Best,
Joaquin
Best,
Joaquin
Hey Joaquin I plan on doing the exact same thing! Any pro-tips on the install??? would you mind taking some pics of your install?
Thanks man! I live in NM and it get hot AF here...
Carl
SeasonedStalker
Carl
I mistakenly didn't take any progress pictures, I was racing the clock on borrowed garage time. I used 9ft of TOC hose from Auto zone and ideal Tridon stainless micro #4 clamps for all connections with double clamps at the cooler connections. Mounted in front of the radiator on passenger side with double zip ties, not the ones from the Hayden kit, to the center and side radiator supports. Re located the horn in line with the center support. Left as much space as possible between the trans cooler and radiator. Feel free to pm with any specific questions.
Best,
Joaquin
Best,
Joaquin
Awesome stuff, though I've got a few questions:
  1. Did you have to drain CVT trans fluid - and if so, did you replace it with new?
  2. Did you follow any guides online, either written or as videos?
  3. Can you provide pics of it done? That'd be super helpful!
SeasonedStalker
I dunno about have to but I planned my cooler install to be done simultaneously with a full fluid drain including pan drop & new screen filter following the instructional here on the Forum. I use amsoil synthetic CVT fluid as a replacement which has been vetted on the NASIOC forums and have been very happy with the results over the last 2000 miles. ('14-'18) - 2017 - CVT Automatic Transmission, Fluid Change Procedure.
21 - 32 of 32 Posts
