1 - 1 of 1 Posts
2003 XT Cross Sports
I have been looking at these 2 cars both priced the same both are 2003 models.
Why have a posted here?
Mainly to address the fears of fuel consumption and high maintenence of the forester. Please give me advice. Specs are below:
Caldina:
GENERAL
Body type Wagon
Drive FULL 4WD
Transmission Super intelligent 4 speed automatic (Super ECT)
Displacement, cc 1998
Frame LA-ST246W-DWPZZ
Price of new car, thousands yen (Tokyo area) 2710 (~$22500)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4510 x 1740 x 1445
Interior dimensions (LxWxH), mm 1905 x 1455 x 1165
Wheel base, mm 2700
Treads (F/R), mm 1505 / 1505
Ground clearance, mm 145
Curb vehicle weight, kg 1480
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 5
Min.turning radius, m 5.6
Fuel tank capacity, l 60
ENGINE
Engine model 3S-GTE
Max.power (Net), kw(PS)/rpm 260 ps (191.23 kw) / 6200 rpm
Max.torque(Net), N*m(kg*m)/rpm 33.0 kg*m (323.62 N*m) / 4400 rpm
Power density 5.69
Engine type Serial 4 cylinder DOHC16 valve turbo
Engine information
Fuel system EFI (electronic fuel injection) (Ci (central injection)
Turbocharger Turbo
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 9
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.4
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 215/45ZR17
Tires size rear 215/45ZR17
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front Strut type coil spring (stabilizer attaching)
Suspension system, rear Double wishbone type coil spring (stabilizer attaching)
Cross Sport:
• BODY / EXTERIOR DESIGN / DIMENSIONS
Body Type: Off-road vehicle 5 doors / 4 seats
Weight: 1430 Kg
Length: 4445 mm
Height: 1550 mm
Wheelbase: 2525 mm
Front Track: 1500 mm
Rear Track: 1495 mm
Ground Clearance: 170 mm
Fuel Capacity: 60 liters
• ENGINE SPECIFICATIONS
Engine location: front
Engine alignment: transverse
Drive Wheels: Four wheel drive
Steering: n/a
Fuel Supply System: EFi
Max Power: 219HP (161 kW) @ 5500 rpm
Max Torque: 309Nm @ 3500 rpm
CO2 Emissions: n/a
Engine Coolant: water
Displacement: 1994 cc
Bore: 92 mm
Stroke: 75 mm
Cam Design: DOHC - Double Overhead Camshaft (per bank)
Cylinders: 4 FLAT
Valves per cylinder: 4
Total Valves: 16
Compression Ratio: 9:1
Aspiration: Turbo
• CHASSIS / BRAKES / SUSPENSIONS
Front Brakes: n/a
Rear Brakes: n/a
Standard Wheels: n/a
Standard Tyres: n/a
Suspension Front: n/a
Suspension Rear: n/a
• TRANSMISSION
Transmission: automatic
Number of gears: 4
• PERFORMANCE
Acceleration 0-100 Km/h: n/a
Acceleration 80-120 Km/h: n/a
Top Speed: n/a
• FUEL CONSUMPTION
City: 11.9 l/100km
Road: 7 l/100km
Mixt: 8.8 l/100km
1 - 1 of 1 Posts
