1 - 7 of 7 Posts
2002 Forester
Okay.. I just read the thread about towing.. Ughh.. I didnt know.. I towed the 2002 automatic trans Forester that I just bought using a U-Haul Dolly with the 2 rear wheels on the ground. towed it about 20 miles at speeds up to 55 MPH. I was able to drive the car off the dolly and about 20 yards into a parking space before shutting it down. I haven't driven it since, because the engine has a piston slap problem that I'm planning on start working on this weekend..
how bad did I just I screw myself and my transmission by the tow?
I have to pull the engine to repair it anyway, but where should I begin to look to see if I screwed up the transmission?
02 Foz 4eat
20 miles may be ok. Only way that I know to "test" it is to actually drive it. You putting in a new engine or repairing this one? If replacing, just go ahead and drive it and see how the trans acts/sounds.
You'll probably be fine. My buddy towed his 92 legacy before he knew not to and he had no problems. He went about 25 miles but kept it under 50. The problem with an automatic is that the transmission won't be cooled as its spinning and will overheat. With the awd the front wheels (tied down) are trying to turn the same speed as the rear and so the center diff is spinning and heating up.
2002 Forester
thanks.. I'm gonna try to repair the engine first.. (if you're interested, see my other thread for pics) if I can't fix it, I'll pick up a used short block on ebay or something.. after I get the engine back in, I'll put it up on 4 jackstands and see if all the wheels turn.. if they do.. I'll put it down and drive it..
I'm keeping my fingers crossed..
1 - 7 of 7 Posts
