1 - 11 of 11 Posts
2004 Forester XT 5MT
Alright hopfully this is a simple fix. Got some oil pooling up directly underneath my throttle body and i can't seem to get it fixed! now here's what i've discovered, there is a hose connectiong the block to a black are line that i know the oil is seeping from so i know where the leak is just unsure for a fix since i worm clamped it really tight and STILL oil blows throw! so i'm confused why i'd be getting that much positive crank press out of complete no where!!! any help guys would be fantastic!
Thanks
[/URL][/IMG]
2007 FXT Sport M5
You must be getting a lot of blow-by to get that much pressure. Is your A/F ratio good or are you running lean and buring your piston rings?
Discussion Starter · #11 ·
A/F are good, the only thing is i had the breather line unhooked to the turbo inlet so it wasn't getting vaccum. but not its reconnected and still doing it so some on nasioc think i blew out the hose and it needs replacing.
1 - 11 of 11 Posts
