2010 FXT Auto4
I have big crack from the wastegate door.Any sugestions what to replace it with? I don't really don't want to get a retune if possible.Thanks for your sugestions.
2008 FSXT M/T
although bothersome, most wastegate cracks dont really effect performance. ive seen turbos w/ the crack put out the same consistant numbers...
2004 fxt A/T
If the crack is in the turbine housing then you are fine, I would say every VF39 has this crack or is about to. There is nothing to worry about if this is the case. If the crack is in the wastegate flapper arm, then I would like to see some pictures. This could be a problem unless you are catless.
