2001 Forester sf5 Manual
Hey guys just after a bit of advice/info on my sf5 turbo.
I'm getting to the point now where I will be getting it ecutek mapped as the handling /brakes are all sorted ,so I will swap to a td04 before the map,question is do I leave the td04 actuator on or swap it out for the old one?
Next up is I'm going to be changing the oil n filter at the same time,what's the best thing to take off to stop the engine firing so I can get the oil pumped round the engine?
Many thanks .jamie
97 JDM S/tb Manual
My mechanic showed my something I've never seen before (no not that)
He got a bit of old cable flex and connected the starter motor straight to the battery. Seemed much simpler than disconnecting the crank sensor especially if you have big hands ( as I do)
This sounds a great idea. Thanks
