Surely appears to be a thermostat problem. Only other explanation is a blockage. Be sure to bleed all air out of system.
good luck
good luck
How to bleed air out of system? That just seems to make sense. I'd like to try that first. And how could I check for a blockage? Thanks TF as always, your advice has been invaluable!Surely appears to be a thermostat problem. Only other explanation is a blockage. Be sure to bleed all air out of system.
good luck
Um, just did a quick Google, ehow says take off rad cap, run till hot, if air is in system it will "burp" out the radiator... does this sound right?How to bleed air out of system? That just seems to make sense. I'd like to try that first. And how could I check for a blockage? Thanks TF as always, your advice has been invaluable!
I'll try that- definitely had air bubbles coming up, but that was without elevating the front. It's taking longer than a couple minutes. I let it cool off while running some errands (including getting a spare thermostat/gasket just in case, hope I can just return it when all is said & done) will take it out for another spin in a few...Get the front end up in the air on some ramps to make the bleeding easier.
