1 - 17 of 17 Posts
2005 Forester XT
Hello,
I noticed my coolant is a little low on my 2005 FXT. What is a good coolant to use to top off my resovior, and does anybody know the brand of coolant that Subaru dealerships use.
Thanks
I just use OEM coolant but nobody really knows what the real brand is behind the OEM stuff. If you do not use OEM stuff, make sure to use something that is safe for aluminum blocks. If you're running low, make sure to check for leaks and cracks in the radiator cap seal too. Might just be evaporation, might be something more (in my case, leaking t-stat housing and bad radiator cap).
Hello,
Thanks
My Subaru dealership uses SHELLZONE coolant, which was a surprise to me. I figured it would be magic Subaru coolant. :icon_eek:
When I had the coolant changed at my dealership, I figured I'd buy a gallon to have at home. I was surprised it wasn't Subaru branded coolant! :confused:
I'd suggest checking with your dealership to see what coolant they use & get the same. :wink:
2015 Highlander AWD XLE 6AT
2010 Forester 2.5X
Would it be brown because some tech decided to take a shortcut and use green coolant with blue coolant?
2002 Forester S
Massive debate on best coolant. Subies use aluminum blocks and heads. Japanese (incl. Subaru), unlike Euro manufacturers, like phosphate based coolants.
Other web pages say that OAT based coolants are best for aluminum engines.
We really need to look into this better.
Then there is the issue of the Subaru cooling additive and conditioner. Subaru factory recommends using this stuff. However, the local Subie mechanics including those who work at the dealers say heyll NO! Turns out the Subie conditioner is a mix of real deal conditioner, plus a butt load of stop-leak. Why the load of stop leak? Head gasket issues, band aid. Problem is all that stop leak clogs the heater core and radiator. Local guys who actually work on Subies do NOT use it. YMMV.
2019 Crosstrek 2018 XT
Tremo;690341 Head gasket issues said:
Subaru Of America endorses it. That's good enough for me. The stuff is more of a preventative than a band aid. I think it makes sense. Subaru has 2 HG's and HGs on any car can leak. What's the problem.
2010 Forester 2.5X
Only 5MT available.
On the subject of factory delivered cars with stop leak in them... I believe GM was doing this too. Had some "Bars Leak" in with the coolant ...just in case.
I've used Bars Leak on a 95 T-bird with chain driven OHC V-8 that would emit steam from tailpipe after warmed up. Worked. Head off that thing would've been $2500 and car only worth $1500. Finally donated it to The Salvation Army to be able to park new Subie in carport. Motor still ran good.. rest of car absolutely falling apart.
2002 Forester S
2 HGs, BFD. My old IROC has 2 HGs as well and it doesn't leak a drop. If it clogs the heater and radiator, that's a problem.
Then don't use it. Its a free country.....
I have it in there for 2 years and even put it in my 01 Nissan Sentra which has no history of HG leaks.
1 - 17 of 17 Posts
