Hello, New to the Subaru Brand but decided to buy one for my son. Price was right, mileage was high. Looked through posts but did not see anything that matched up with the problem I am having.
It had coolant, now water dripping out from above the thermostat housing. Well the drip turned into water pouring out after a flush of the system. Appears to be center of the vehicle. I am thinking water pump. I did hear a squeal a couple times at start up.
It runs fine. Never overheated. Cooling fans kick in. I have heat. I checked oil, and it's not mixed with water. Before I broke this thing down to get to water pump, I thought I would try you guys and see if anyone had a similar issue.
I did flush system and had some stop leak which dumped out on the ground. prob. a no no but thought I would try it. It didn't stay in long.
Thanks
Thanks
