1 - 2 of 2 Posts
· Administrator
@Frank_Bama the use of the Subaru recommended Coolant Conditioner (SOA635071) Conditioner has generated some heated discussions, as has the addition of Red Line WaterWetter, but I can tell you we have both in our Forester coolant, installed by our trusted dealership shop. :wink:
From the '99-'02 FSM:
B: FILLING OF ENGINE COOLANT
1) Fill engine coolant into radiator up to filler neck
position.
Coolant capacity (fill up to “FULL” level):
MT model;
Approx. 6.0  (6.3 US qt, 5.3 Imp qt)
AT model;
Approx. 6.2  (6.6 US qt, 5.5 Imp qt)
CAUTION:
The SUBARU Genuine Coolant containing antifreeze
and anti-rust agents is especially made
for SUBARU engine, which has an aluminum
crankcase. Always use SUBARU Genuine
Coolant, since other coolant may cause corrosion.
Take a look at these links:
TSB 09-42-05 Engine Coolant
All About SUBARU Cooling System Conditioner SOA635071
Coolant/Antifreeze
1 - 2 of 2 Posts
