you would have to import the engine and trans with the PCM, and the wiring harness, then swap it over, run all new fuel lines and a fuel tank, which you would have to import as well, and then if you ever needed parts you would have to import them too, so it will be costly, and over the long run it would not be worth it, besides being able to saw you have a, if not the only diesel forester in n/a
