Hi hope someone can shed some light on this!!
Car has decided it keeps losing oil, but it only drops to a certain level on the dip stick then doesnt seem to drop any further its about 10mm above the low mark. i can top it up with 200ml but in a week it goes back to the same place and stays there!
now i only do about 12 miles each way every day, so the car is started and run from stone cold both ways, ive checked at start up theres no sign of blue smoke of any kind and when i get out at the end still no signs of smoke.
im just wondering if thick cold oil, and a new cosworth hp pump is causing me to blow oil out through the pcv?
even if i give it some welly theres no smoke coming out!!
breathers have some oil in, and a bit of condensation residue but i cant see anything untoward.
ive run the car with the oil cap off and theres no internal pressure build up, and no smoke or gases being ejected through the filler neck.
