1 - 1 of 1 Posts
F
Guest
Hello,
my car is operating normally without any problem, its running smooth. I had it scanned at the dealer and it throwed codes 23 and 24. I have just disconnected the battery so i can clear the codes and check them back later if they come back.
Speculating, what could have caused those codes to come up in memory?
23
Air flow sensor
Abnormal voltage input entered from air flow sensor
Controls the amount of fuel (injected) in relation to engine speed and throttle sensor position
24
Air control valve
Air control valve inoperative (Abnormal signal produced in monitor circuit)
Prevents abnormal engine speed using "fuel cut" in relation to engine speed, vehicle speed, and throttle sensor position
thanx.
1 - 1 of 1 Posts
