2006 Forester LL Bean edition
I have poor idle, poor acceleration up to about 1500 rpm's and code P0336 every other time i start the car. After I clear the code, it runs better. I changed the timing belt, and this started. I have checked the belt twice since install and it is dead on. I changed the crankshaft position sensor and no change. There is one tooth broke off the crankshaft gear, could that be my problem?
Any advice is helpful, I am out of ideas.
Tire Wheel Automotive tire Light Tread
Sent from my SM-N960U using Tapatalk
@butwutami welcome to the forum from Oregon!
No expert on this, but I believe that broken tooth, looks like a fresh break, is part of the Crankshaft Position Sensor circuit, so that could be the cause of your P0336?
02 wrx 06 sti 06 legacy gt 09 forester 13 legacy 3.6r
The broken tooth is the problem. You will need to replace
