2007 SG9 Forester XT Stick Shift
Anybody use ixizSclutch clutch travel stopper. IxizConcept
Does it work?
One of my biggest gripe about my 07FSXT is the shifter feel and clutch feel. This might help one of my problem with adjusting the clutch to release sooner but causing pedal force to up.
I adjust the clutch up last night just to experiment and it does makes the clutch feel a lot lighter since you do not have to compress the spring all the way in. I might try to experiment with small screw today.
Bought some #8-32X1" screw, Star washer, flat washer and Plastic screw caps from Home depot. Total spend including tax $4 and so far I am impressed with the result. The plastic screw caps is a must. It act as a damper instead of hitting metal to metal.
Took about 2 minutes to install the spacer but about 30 minutes to adjust the clutch start switch and clutch pedal adjuster rod. It should be a lot faster next time since I know it should only took 2-3 turns to put the clutch cancel switch where it need to be.
