Any idea guys?
I'm having the same problem almost exactly. With the clutch fully depressed in first gear, I can release the pedal about half way without the clutch grabbing anything; I literally apply no gas and the RPMs do nothing. It's like the pedal effects nothing.im having a similar issue. when the clutch lets out there is movement that makes it not smooth to shift. like you can feel it release at one spot before the pedal comes all the way up. im thinking it is the soft motor mounts .so im gonna try the groupn motor mounts since i already have the group n tranny mount.
from a spirited 1st to 2nd gear change the whole driveline seems to lunge forward and bog before ramping back up. hopefully the mounts will help
