1 - 1 of 1 Posts
00/4 Forester S, X Auto, Auto
Been searching for a while and haven't seen a consensus on a good answer.
2000 S with an ADF 2 inch top hat lift, trailing arm spacers, new KYB struts and Cooper 215/70R16 tires. Love the ground clearance and comments.
The issue I have is as the passenger rear is compressed ( driver side unloaded ) there is a loud clunk. I have removed the rear sway bar.
I have seen answers such as wheel bearing, differential mount bracket loose and bad struts. What has any of you found that may cause and fix this issue. Have had the lift over a year and it still hasn't seen a trail cause I'm worried about damage that wound cause me to be stuck without a good escape route.
Thank you for any replies!!!!!
Pick for attention!
[/URL][/IMG]
1 - 1 of 1 Posts
