1 - 2 of 2 Posts
Super Moderator
On my 2018 Limited when I direct the air flow to just the instrument panel or just the feet, I get a what I consider a normal amount of air flow which of course varies with the fan speed. However, when I re-direct the airflow to both the instrument panel AND feet (bi-level), I get a huge reduction in air flow which leads me to believe that I may have a malfunctioning damper in the ductwork. I would estimate that on the bi-level mode the air flow reduction to the instrument panel vents is about 85%, instead of the usual 50% reduction that I have experienced in other vehicles including a 2010 Forester. Air flow to the foot vents also is also reduced by about 85%, so it's not like it's directing more than half of the bi-level air flow to the foot area.
If you have a 2014-2018 Forester, can you tell me about how much air flow reduction you experience when you direct the air flow to both the instrument panel AND foot outlets. Thanks.
2018 XT Touring CVT
I don't think there's any reduction in the total air flow, but I think the flow to the dash vents goes to less than half. But sometimes I get a burst of air to the dash vents which I can feel and hear.
Generally, if I don't like the amount of flow to the dash vents when the foot vents are on, I manually turn up the blower.
But honestly, the automatic setting seems to work pretty well, so if I change it, I don't feel as if I'm getting a lot of benefit.
1 - 2 of 2 Posts
