1 - 7 of 7 Posts
2003 Forester 2.5XS automatic
Hi, newbie here. I'm not too well versed in cars and seem to learn through trial and error, but mostly when things go wrong.
My vehicle: '03 Forester 2.5XS, 160k miles, automatic
Problem: There's a clicking from behind my glove box that starts when I turn the engine on and stops when I turn my engine off. I took off the glove compartment and checked my air filter...it definitely needs replacement...and I knocked off some loose things on the filter and put it back in (I will go out later for the replacement filter). When I started that engine again, the clicking noise was still there. I couldn't pinpoint the exact location, but felt near the air filter and found that the sound is coming from a small black box, attached to the filter but two difficult to access screws). I found out by doing a general online search that it's an actuator, but I have no idea what it's for. It also looks like I have to remove at least one or more things to remove the actuator.
Has anyone else experienced this? Does anyone know what this actuator controls? If/when I remove things to get to the actuator, I don't really know what I will remove. Also, does anyone have any advice on how to remove the white electrical connector? Do I just yank the white connector hard?
Thank you,
Scott
2007 Forester Sports XT Manual
That sounds like the temperature blend door motor. Can you control the temp of your A/C?
Thank you for the reply. I can control the heat, but haven't tried the A/C in a while since I haven't needed to use it for the past few months. I will see if that is an issue.
Thank you,
Scott
Can you switch between all of your vents? It could be a mode door. I'm not sure if yours are vacuum operated or not.
UPDATE
I have gotten the part half off. The screw near the engine side is very difficult to remove...I think I loosened it. I can see that a plastic part is broken and my be stuck inside. The part looks like it controls a flap above the blower motor. I hope to get it off soon and will bring it to Advance Auto Parts, but I'm having trouble even finding something online that can give me more information.
Part: Zexel 502752-3350 28512 12V
Picture: http://www.subaruforester.org/vbull...69-heat-regulator-picture9033-img-0341-2.html
I searched Zexel's website and found nothing.
Well, I keep stripping the screw and it will be that much harder to screw it in if/when I replace it. I'm leaving the motor unplugged. I can still get heat and AC, but cannot control it was well.
I was thinking about removing the blower motor. Does anyone know how to do that?
1 - 7 of 7 Posts
