1 - 20 of 20 Posts
2006 06 FXT & 05 OutB XT 6 Speed/DCCDPro / Auto
Hello everyone. I just picked up a STI tmic and its a bit dirty i was wondering what I could use to clean it up. Any idea..??
Thanks for the help...
K.I.T.T. meet A.L.I.C.E.
2008 Forester XT 4EAT
Will it remove oil buildup inside of the intercooler? Mine's off the car now and pretty oily inside.
For the inside, you'd want to use a solvent degreaser to remove the oil & then blow some air thru it to dry off the remaining solvent that doesn't pour out. :wink:
Pardon the n00bness of the question, but what would a recommendation be for a cleaner?
Some people use a Simple Green and water solution, rinse, then dry it out with a bit of compressed air.
Obviously, as long as it's not still full of the solution, it'll be fine going back on your car a little wet.
I'm sure there are many different IC cleaning concoctions.
w w w.simplegreen.c o m/solutions_faqs.php?search_query=aluminum&search_query_backup=danger]Frequently]Frequently Asked Questions
The Sub kit guy
2005 Forester X & XT VF39
I've always had good results with simple green and a nylon brush. It doesn't bend fins and comes out looking like new.
2004 fxt A/T
Hmm...will have to give it a shot...have you used it yourself?
Yep, works extremely well and the stuff is safe plastics as well so if you get a little over spray it will not melt it. You don't even have to scrub just rinse off with water and respray if needed. It has always worked first shot and I have never had to reapply. Simple green works well it just doesn't lift the grease and contaminants away without a brush or cloth.
Discussion Starter · #11 ·
Thanks for all the ideas. Headed to homedepot right now to get both and give them a try. Will take pics if I can find the camera.
2011 CT200h/E90 M3
To clean, I'd use some engine degreaser then rinse. If it's not too dirty, Simple Green and a water mix works well. That's what I usually use when I clean my engine bay.
But I know a lot of the WRX guys use gasoline to clean out all that junk. I haven't tried it myself, but I hear it works wonders.
And safety pin or a pair tweezers will be useful in straightening out any bent fins.
Here's a picture of mine before I installed it, somewhat clean and 95% straight fins. I definitely could have sanded it down and polished it, but I was lazy.
none none
I use some plastic wrap and rubber bands to cap off the outlets and fill it with a simple green solution to clean the inside. Shaking it works most of the oil residue out.
That A/C cleaner looks like a great idea for the external surfaces and fins. Someone locally mentioned using muriatic acid for cleaning a BPV, and I feel it would work well for the exterior of an IC as well (maybe, haven't tried it though!)
2010 Forester 2.5XT SH Manual
On the subject of bent fins; what is the best way of repairing bent inter-cooler fins? Some of mine are quite bent from possibly large bugs and stones entering the scoop at high speeds. I believe there is a sort of "comb" one could use, but have never seen one...
2004 FSTI automatic
Toothpick works well for bent fins.
Does anyone know where to get a STI stencil for the tmic? I would like to repaint, and dont want to try and mock up a stencil.
6 subies in, current '02 jdm XT SG Forester
tmic is coming off tomorrow, will post pics of what some f***head did to it. have electrical contact cleaner, crc, a few screw drivers and tweezers to straighten fins. over 90% bent, and being an apprentice, no $$$ to replace!!!
04 FXT, 61 Stude
I've heard using radiator paint on these things works great, anyone here use it?
1 - 20 of 20 Posts
