Will be bringing in our car to have dealer inspect.
Have recently had BOTH recalls addressed (fuel tank and fuel injection thing seperately).
Each time I fill up with gas since then (twice)......"check engine" AND "cruise" signs come on. (The first stays solid, the other keeps blinkin'). When gas gets down below half-full, both lights simultaneously go off. Cruise control then works normal again !
Have read owners manual regarding Check Engine deal could happen if gas cap is not put on right at fill.....so I blamed the gas attendant ! But second time went elsewhere, different attendant, and I checked to be sure cap was tightened properly......no problem. Well, once again, after say 20 miles, same deal.
Oddly, this second time, the lights went away after 1/4 tank used up........BUT, soon came back on.......shortly after making long tight curve at a highway exit.
Have checked oil and engine temp, and all seems in order. Engine still purrs like a cat. Lack of cruise control is irritating !
Have an appointment to get it checked out..........in meantime, any fellow Subaru Lovers have thoughts on really! this problem could be on a 42,000 miles '08 Forester ??
Thanks if you do !!!!!
