I'm switching out my suspension to 06 wrx struts and 05 sti springs with 1/2" saggy butt spacers (also using the longer top hat studs) and then getting my alignment set to -1.0/-1.5 F/R.
Now.. I'm thinking about picking up stock 06 wrx rims (17x7 +55 offset) and puttin on Continental ExtremeContact DW's in 235/50/17 size. I've used the tire calculator and from what it says, all should be fine with the exception of a 0.3% speed difference and a few mm changes here and there.
Questions are - will i have any rubbing issues? With or without people in the car/loaded cargo space? Will the tire size fill up the gaps, if any, nicely? Is the tire size I'm considering too wide or too thin for the wheels I'm getting?
Thanks in advance.
Thanks in advance.
