My centre console is badly scratched and Subaru UK are quoting £198 for a replacement! so my question is anyone know the paint code, it's for a 2007 XTEN and it's silver
Damn I thought no one had seen meThats what you get for going sideways around sharp left handers and trying to cling on to the dash.
Cheers, I'll give them a tryAsk your local paint shop/motor factor for 'silver' paint sample sheets - then take away for closest match
Thanks I'll see if I can find something equivalent here in the ukI hate the silver and am going to paint mine black soon.
I had good luck painting the instrument cluster surround with Krylon Fusion paint (meant for plastic) in a Satin Khaki color that matched my beige interior.
Some say the spray Plasti-Dip product is good if you use a lot of coats and can be peeled off if you change your mind. I haven't decided what I'm going to do yet.
:biggrin: I like your style! So did you go over to the States just to change someone's brake pads?that silver coating aint the best.
i hired an outback over in the USA and got some copperslip inside on the silver door handles.
i sprayed a little brake cleaner in a rag to wipe off all the copper grease. it instantly took off all the silver.
it looked awfull. so before i handed it back to avis, i used brake cleaner to remove all the silver on both the passenger side and drivers side, then got some WD40 and made it shiney black!!!!
no questions asked!...
