none none
Thats the code for the uppipe EGT sensor. No idea why its only coming on while cruising. You can do the resistor mod to replace the sensor, but I'd probably throw on a catless uppipe at the same time or make sure there isn't a problem with the cat. Its possible your uppipe cat is disintegrating and bits are going through the turbo!
2004 FXT 5MT
Gotta oem sti uppipe in the mail and should be here tom.
Its just odd that it only does it when I try to use cruise.
