Fast & Dirty
2009 Forester XT 4 speed auto
Well I am considering a CB radio incase something happens well in the forest with no cell phone coverage.
Handheld units would have a slighter smaller range?
in Dash would mean mounting it in my dash. Not a fan.
Would I notice a BIG drop in performance one vs the other?
2009 X
Yes, your typical hand held unit will have a much smaller range than a dash mounted unit with a properly installed and TUNED antenna. You can get smaller units that can mount under seats, in a glove box etc if you look around Im sure you can come up with one. There are some pretty compact but powerful options out there.
2004 XT AT
As Toyman says, the performance is really all in the antenna system. But a handheld with an external antenna is just as good as a mounted rig, except in terms of convenience. For casual/occasional go for a large magmount with a tallish whip (but not impracticably tall - a 4-5 foot long base loaded steel whip on an 8-10 inch base is a good compromise). Small magmounts should be avoided as they netheir hold well nor couple to the car's roof (groundplane) well.
-- Steve
2009 Forester (MT)
I just use handheld CB radios with GMRS channels. Some of these handheld radios transmit from 1-5 watts of power, which is a lot more than a CB radio (1/2-watt). However, as will all radios, the the signal is transmitted in line of sight. It means that the signal may not make it very far through a forested area, and won't make it across a mountain, buildings, etc. The ones I use reach approximately 30 miles. Also GMRS radios require the purchase of an license that costs around $85.00. The license is good for a whole family, and five years.
GMRS General Mobile Radio Service
