Thanks a lot for this, just to clarify for myself - So the only pipe on the SH that contains a cat is the downpipe? So basically, if I replace the downpipe make sure to get a cat'ed one?Seems like theres an upper and lower Cat on our models. Depends on how they do your emissions test. Many places will only check for a CEL light and not check the actual emissions on a newer vehicle. You can always put a higher flowing catylitic converter in place. The Catted CNT downpipe is the cheapest i know of. Something in the mid 300 dollar range for the whole pipe. You'll want a tune after switching though.
Edit: Only 1 pipe contains both cats. There is no cat on the uppipe like the older models. The downpipe coming out of the turbo is the only pipe. The mid pipe contains a resonator thats kinda boxy and flat but it's not a cat.
Sorry, one last question - I've read that replacing the DP with an aftermarket one can cause the CEL light to come on and cause issues. Is this something that can be easily fixed without doing any damage while working correctly?Yes.
