2019 Forester Sport CVT
I'm new here, so i apologize if my search didn't find the answer to this one. I'm having a hard time changing my date/time on my Sport. Most times when I go in to change the date/time it's greyed out and I'm not able to select it. The odd time it allows me to change the time/date. It doesn't stick?
Am I doing something wrong? Is this a known problem? Also, how do you change your location? I read the owner's manual atleast for the time/date.
Thank you for your help and patience!
Discussion Starter · #2 ·
Delete
I found the solution. Thank you search function. This post can be deleted. :thumbsup:
@The Belgian I'm going to guess one these threads helped. I'll add "SOLVED!" to your thread title. :wink:
2019 clock issue - every time I restart the car?
Auto clock setting won't work - SOLVED!
also...
