I have two Subaru Foresters. Thus, I thought it would be worth it to invest in a scanner, so I can figure out the problem when the check engine light comes on without bring it into the mechanic every time. Can some recommend a good scanner? Thanks!
I see this is your first post, so welcome to the forum from Oregon! :biggrin:
I have a shop grade scanner & I find the Scangauge II is what I use most. It's a bit more expensive than a low cost scan tool, but it does so much more. I see you're not in the States, so if you do decide on a Scangauge II, make sure it will work on your Forester! :wink:
As to other scanners, try a forum search "code scanner" or "scan tool", with the quotes. :smile:
For years I have used the following. It attaches to a laptop. When necessary I can plot any sensor and determine if they are going bad ( slow response ) and look at freeze frame data. I bought it back in 2000 and have used it many times since. But it is OBDII ONLY. Anytime I need to 'Dig in' to find the problem, it has never let me down.
Now 3 years ago, I bought a small scanner which is not much more than a code reader, but it works on OBDII AND CAN bus. I keep it in the back of the Forester and have used it more than I would imagine, especially when someone tells me their 'Check Engine Light' is on. No freeze frame data, pending or Stored codes. Only the current codes that are turning on the light.
