2009 Forester X Touring 5M
Is there camber plate available for the new Forester model?
Front and Rear that would work with OEM strut perch? :icon_question:
Is there camber plate for the rear? Model compagny that does them?
Seeing as the 08+ WRX/STI struts bolt into the SH, Im thinking you could just bolt the camber plates on also....or mod slightly to fit? Just guessing here.
none none
Pretty sure the fronts are the same fitment as they've always been so front camber plates are likely the same as all other years.
There are no rear camber plates for the new style rear suspension as the struts don't control suspension geometry, its all in the suspension arms/knuckle.
