2009 Ralliart SST
trying to replace pads and rotors but the lower bolt that holds the front strut is in my way. i take it i have to remove this bolt in order to pull of the front caliper? if i do will it affect my alignment?
Smooshed FOTY 2011
I've done brakes 3 times, and I only remove the 4 bolts needed, the two on the caliper, and the two holding the caliper bracket. The bottom caliper bracket bolt I use a wrench for instead of a socket, but I have never had the need to remove any other bolts.
