This is what the manual has listed...... is there special produce since this car has abs?
bleed proceedure I have been told by every mechanic I have worked with has always been start with the wheel farthest from yhe M/C and work your way to the one the M/C is sitting nearest .yet everything i have been told to do is bleed and replace back to front........
All the above information seems quite comprehensive. Are you having Brake problems? Can you elaborate?Is there anything else which can be done?
