Got back from a trip very late the other night and drove home from the airport and to work the next day, everything seemed fine. Coming home from work yesterday I was taking off from a stop I noticed my forester being laggy and slow. I look and see I'm only making maybe 1 - 3 lbs boost even with my foot down. Every once in a while when I put my foot down it will climb to 5 or 8 maybe 9 and sometimes even shoot to 11 but won't hold there. For the most part it just goes from the vac side to around 0 -1 ish. I got home and checked for codes. I didn't get any (no cel ) nothing pending either. I took a bright light and inspected for any hoses that were off. Couldn't find any. I removed the intercooler to see if there was possibly a hole in the Samco hose but that was fine too. The wastgate kind of felt like it was binding a little when I tugged on the rod with some pliers. I took off the heat shield on the turbo to look for exhaust leaks and check the action of the wastgate. I think the arm was working OK. I rotated the C-Clip and put some never seize in the area since it looked a little rusty. For good measure I double checked with my Access Port that I was still running the proper map. I cleared the ECU with the AP and put the same map back on over top of itself.
Next I went for a ride and it ran a lot worse then before. The boost seemed to work fine but it was bucking, stuttering and generally running like poop. I almost didn't make it home :icon_mad: Still no CEL's I also checked for codes again.
Next I popped the hood to see if I left a hose clamp undone but could not find anything. I started the car and went for another short drive (at first) then since it seemed fine another much longer drive. Now it seems fine :icon_confused: I let it sit overnight and now I'm about to go for another drive. I'm a little baffled at this point. Could it be the Boost control solenoid?
Something I noticed that I'm unsure about, I checked the Recirc Valve when I had it off. The main opening where the recirc hose goes in was sealing fine. However, where the vac line hooks up, I was able to draw air in with only a little resistance. I was under the impression that diaphragm was sealed. I'm wondering if I have a recirc valve issue? I checked the vacuum with the hose off and plugged. It went from about with the recirc hooked up to 19 15 in/Hg with it removed. Still even if it has a little leak I don't think that would create the boost issue or make it run poorly.
I'm open to suggestions, I may put a request in the wanted section for an OEM BOV to see if anyone has a unit I can get and see if that helps a little.
I'm going to go for a drive now and see if it's still running OK like it was when I parked it yesterday and I'll report back.
