I thought I had my bases cover b4 attempting the 2 belts.
The belt that drives the PS pump is a piece of cake.
The belt that drives the AC is not a piece of cake. Do I need to remove the entire fan assembly to loosen the locking bolt? so that I can loosen the pulley so I can get the belt off?
You can not fit a socket and ratchet in there. I tried both an open end 12mm and a closed end 12mm. I can see that I'm about to "round" off the nut so I stopped hoping that one of the forum members might have a tip.
Thanks.
Thanks.
