ok... one of my major gripes...
I did the mod, which attaches a PC fan to the end of the sensor tube, sucking air...
it seemed to be an improvement right after I finished the mod, mind you the weather was getting warm at that time..
this time, in the dead of winter, the hvac just sucks lards... when the car first starts up, the system blows HOT HOT air... waaaay past the set temperature... often I have to open the windows cuz it's so hot... it's probably a good 5-10C over the set temperature...
then after awhile, prob. 30min, it gets COLD, prob. 5-10C colder than the set temp... at which point, I usually have to manually override and increase the temp cuz it's so cold...
this seems to be even worse than OEM.. I checked the fan, it's still spinning, and it's still connected to the tube...
WHAT'S GOING ON ?
Anyone shed some light ?
WHAT'S GOING ON ?
