G
I own a 05 XS with about 7500 miles on it. When I use the auto climate control for heat or defrost when it is roughly 40-45 degrees outside, the system blows hot air. Even with the temp control set at its lowest, the air is uncomfortable. I see no sense in running the defroster with a window cracked open. Is this a quirk in the system? Anybody else notice this? I've owned other cars with auto climate but haven't had this much of a problem. Thanks much...
2016 & 2018 2.5i Premium CVT
Welcome!
Ah, if we were back on the old site we'd politely suggest that you do a search, since this topic was discussed there at least a zillion times. But now we're starting clean with the new site, and there are no archives to search here.
Peaty once did an owner satisfaction survey, in which 71% of the responses were like yours.
The best solution known so far can be found at www.geocities.com/samiam_68/SubaruCCS/SSC_Fix.htm . It's so clever that it got written up in the New York Times.
2004 FXT
My CC has been acting all crazy lately.. I think the fan fix i created stopped working due to a bad connection.. will have to check it out.
It appears that Sam has sent Peaty an update... not sure if anyone knows, but check the link above on Scooby Mods... I will try the latest suggestion from Sam and see how that works out...
