1 - 2 of 2 Posts
none none
06+ (model year 06, the facelifted SG models) use the ATF-HP (most likely just to standardize the fluid across their lineup, as the 5eat requires it as well).
A prefacelift SG XT should be fine with dex3, but the ATF-HP is a good fluid. However I'm not sure if you can mix them, so I'd probably do a full flush if going from the dex3 to atf-hp. If you're doing it yourself (and likely doing a drain and fill), I'd probably just go with a decent quality dex3 as long as thats whats already in there.
1 - 2 of 2 Posts
