This is nothing more than a consolidated group of info that is taken from multiple sources. FSM, Various posts and forums. Plain OM had a good post on SubaruOutback.org so much of the Credit goes to him.
The secret handshake. This should work for both Phase I and Phase II
What does that get you and what does it mean? Well it will get you a series of flashes which you need to count.
At this point the AT Oil Temp light will do one of three things:
Phase I codes(roughly 1998 and earlier)
Phase II codes(roughly 1999 - 2004)
- Warm up the engine
- Turn the ignition switch OFF
- Turn the ignition switch ON
- Start the engine
- Drive the vehicle at speeds greater than 12 MPH
- Stop the vehicle
- Depress the brake pedal and move the gear selector to "1"
- Turn the ignition switch to OFF
- Turn the ignition switch to ON
- Move the gear selector to "2"
- Move the gear selector to "1"
- Move the gear selector to "3"
- Move the gear selector to "D"
- flash at a two flashes/second rate indicating there are no stored codes (“normal”)
- flash more rapidly at a 4 flashes/second rate indicating a power supply problem (less likely)
- flash with long and short flashes which is indicating the stored codes, with the long flashes representing “10”s, and the short flashes “1”s, as illustrated here:
- 11 Line pressure duty solenoid. Short or Disconnection in solenoid driving circuit
- 12 Lockup duty solenoid. Short or disconnection in solenoid driving circuit
- 13 2-4 brake timing solenoid. Short or disconnection in solenoid driving circuit
- 14 Shift solenoid B. Short or disconnection in solenoid driving circuit
- 15 Shift solenoid A. Short or disconnection in solenoid driving circuit
- 16 2-4 brake duty solenoid. Short or disconnection in solenoid driving circuit
- 21 ATF temperature sensor. Short or disconnection in input circuit
- 22 Pressure sensor. Short or disconnection in input circuit
- 23 Engine speed signal. No signal input above 10km/h
- 24 Transfer duty solenoid. Short or disconnection in solenoid driving circuit
- 25 Engine torque control signal. Short or disconnection in engine torque control signal circuit
- 31 Throttle sensor. Short or disconnection in input circuit
- 32 Vehicle speed sensor 1. No signal input to speed sensor 1 above 20km/h
- 33 Vehicle speed sensor 2. No signal input to speed Sensor 2 above 20km/h
- 34 Turbine sensor. No signal input in ranges other than N range
- 36 Low clutch timing solenoid. Short or disconnection in solenoid driving circuit
- 11 Engine speed signal. Detects open or shorted input signal circuit.
- 27 ATF temperature sensor. Detects open or shorted input signal circuit.
- 31 Throttle position sensor. Detects open or shorted input signal circuit.
- 33 Front vehicle speed sensor. Detects open or shorted input signal circuit.
- 36 Torque converter turbine speed sensor. Detects open or shorted input signal circuit.
- 38 Torque control signal. Detects open or shorted input signal circuit.
- 45 Intake manifold pressure signal. Detects open or shorted input signal circuit.
- 71 Shift solenoid 1. Detects open or shorted output signal circuit.
- 72 Shift solenoid 2. Detects open or shorted output signal circuit.
- 73 Low clutch timing solenoid. Detects open or shorted output signal circuit.
- 74 2-4 brake timing solenoid. Detects open or shorted output signal circuit.
- 75 Line pressure duty solenoid. Detects open or shorted output signal circuit.
- 76 2-4 brake duty solenoid. Detects open or shorted output signal circuit.
- 77 Lock-up duty solenoid. Detects open or shorted output signal circuit.
- 78 SPORT shift solenoid. Detects open or shorted output signal circuit.
- 79 Transfer duty solenoid. Detects open or shorted output signal circuit.
- 86 VDC communication signal. Detects open or shorted input signal circuit.
- 93 Rear vehicle speed sensor. Detects open or shorted input signal circuit.
