Hey guys, i have just bought front and rear ARB's from an STI impreza, 20mm front and 19mm rear, wheres the best place to get bushes? would a motorfactors stock them or is it an online job?
You MUST torque everything down with the car on the ground (ie the endlink bolts, and the bushing brackets). I found it easiest to put whatever end up on ramps while working on it. You won't be able to get everything lined up if you have the car jacked up.ahh, perfect, thanks.
is it possible to change these with the weight of the car on its wheels, or does it have to be supported elsewhere?
Unless you car has been lowered. Then it is a right PITA to get the bar over the exhaustits a 10 minute job tops!
yeah! well there is that then though! :bacon:Unless you car has been lowered. Then it is a right PITA to get the bar over the exhaust
