2016 2.5i Premium 6MT
I am about to do my 4th oil change on my '16 2.5i 6MT. It has a little over 24000 miles on the odometer. I did the last oil change with a socket, 3 inch extension and a rachet. I have always use a 14MM long handle box end wrench on my 3 Toyotas. It is very easy with 1 tool instead of 3 pieces for my Forester. I know there is a plastic pan that may get in the way of the box wrench. Just wondering if any other members have used just a long handle 17MM box wrench. Thanks.
2014 Forester 2.5i CVT
Just be aware that the Subaru plug is very soft and the points are easy to round off. So if you use a box wrench, I strongly suggest using the closed end of a 6-point wrench, not a 12-point. I use a 6-point socket with a 3/8" ratchet. No extension. But mine is a 2014, so the opening in the plastic "skid plate" may be different than your 2016.
If this is an ongoing difficulty, I would recommend you install a Fumoto valve and be done with using any sort of wrench again.
Thanks for all the replies and input. I will see if I can lay the box end wrench onto the plug securely, if not then I will go back to a 6 point socket, 3 inch extension and a ratchet.
Thanks for the suggestions. I will see if the 12 point box end wrench can access the plug. If it can then maybe next oil change I will purchase a 6 point box end wrench. I agree with the softness of the Subaru drain plug. All three of my Toyotas' plugs are 14MM heads and all 6 points are fine. '99 Camry has 150K. '98 Tacoma has 120K. '06 Tundra has 43K. by the way my '16 Forester 6MT has a 17MM plug head. I know others have the smaller 14MM. Don't know why.
