1 - 20 of 22 Posts
I've been looking at wheels and tires and I want 18's but I want more meat on them than the usual set up (225-45-18, which is slightly smaller than the stock diameter). 235-45-18 seems like it should fit without any problems...its .79" wider than stock, and .17" taller...which knocks the speedo off by 1/2 a mph. Anyone with any knowledge of this, let me know... thanks
No more Foz !
03 Impreza Sti
depends on the wheel offset as well - should be fine with an et48, any higher and a 225 is probably max..
No more Foz !
03 Impreza Sti
Looking at this size also but tyre choice is very limited in the uk with those dimensions..will probably end up with 225/45/18
Mr. November 2008
2015 BMW 335d xDrive GT Auto
225/45-18 is pretty limited too, unless you like Bridgestones...
On mine I could go to 225/40-18 and get a whole load of the popular performance tyres available (e.g. F1's, T1R's, plenty of others) but I'm not sure about the smaller diameter.
Or I could go to 235/40-18, which has some quite good tyres and matches the original 225/45 very closely in size.
Just forked out for 4 tyres on the wife's RX8. 225/45-18's would you believe...
'09 STI
Really? I would think you guys could get the same tires we get in the U.S.in 225/45-18. Like the Bridgestone S03s, Michelin Pilot Sport 1, Pirelli P Zero, Falken RT615, Yokohama Advan AD07, B.F. Goodrich T/A KDW 2, Toyo t1r,
Mr. November 2008
OK, I was exaggerating a bit. In 225/45-18 I can see (in W, Y and Z-rated): *** Corrected typo ***
No S03 as far as I know.
Michelin PS but not PS2
No Falkens that I can find
Dunlop SP Sport 9000 but not the later SP Sport Maxx
P Zero Rosso and Nero - yes
No Goodyear F1.
Toyo T1R - yes, a fairly recent addition.
No Yokohamas
mytyres.co.uk the list is actually 10 tyres available, and blackcircles.co.uk lists 11.
For 225/40-18 mytyres list 66, and blackcircles list 42, including the Goodyears, Yokos and SP Sport Maxx ones.
'09 STI
You said 225 in this post and that is the size I searched. I wanted to go 235/45-18 with an 8" rim but couldn't find tires.
Mr. November 2008
That's my fingers hitting different keys than intended - corrected now.
On mine the rims are 7.5 inch, so 235/40 is actually slightly to wide (for the rim, not the car)
No more Foz !
03 Impreza Sti
I ordered 4 T1R's today from Micheldever tyres :)
Got my PFF7's now and have ordered some 3mm spacers so with any luck I'll have them on by early next week - can't wait :D
btw I tried a wheel on with 225/40/18's to see what it was like and tbh it looked very odd with the stock ride height. Plus the diameter is way out - my speedo already reads about 7% fast as it is :(
can you pls explain the need of spacers?
why not go for 245/40/18?
No more Foz !
03 Impreza Sti
Only needed spacers as the PFF7 Prodrive wheel has an offset of ET51 against ET48 for the stock wheel.
As it happens they were fitted today with 225/45/18 toyo T1r's and whilst they were close to the strut at the back it didn't need the spacers although I might fit them later just to be sure.
A 235 wouldn't have fitted with that wheel though...
Discussion Starter · #16 · (Edited)
so its not good to run 235 on a 7.5" rim?
so if I went with an eight inch rim, and 235/45/18, what offset should I look for?
Is there anyway to run an offset to that it could have a deep look to it... I always get offset confused, but a lower number means it would be deeper or further in right? Example: an offset of 38 is deeper than 50?
G
i am running 225/40/18 (bf goodrich g-force) and completely satisfied with the tire. Somewhat noisier at first but became accustomed to over time. My only concern is the offset of the Motegi wheel, (45mm I think) & if it could cause any harm to the drivetrain over time? More space than I would like between tire & fender, but I will take handling over negative space anyday. No means to slander, but skrew the geolander...
Mr. November 2008
My only source for this is the range of rim widths shown on Tirerack.com when you look at the specs for each tyre. For 235/40-18 the range is 8.0-9.5 inches for the ones I've looked at.
Whether that means that 7.5 is a no-no, or just outside the preferred range I don't know !
'09 STI
It's fine just not optimum. Most manufacturers recommend tires that are 1" to 1.5" wider than the rim (25MM- 37.5MM). Especially when you start getting into 45 series tires or lower. Those short, stiff sidewalls aren't made to be bulged out on too narrow of rims.Llike I said, it will work it's just not ideal.
And by the way, those tires I mentioned eaelier in 225/45-18 are made. don't know if you can get them but they do make them.
1 - 20 of 22 Posts
