1 - 16 of 16 Posts
Harbor Fright
2005 XT
Considering several tires that are on average 25.5" in diameter- does this throw the speedo/odo way out of wack, or is it livable?
2004 Forester X MT
Im 1 inch smaller than stock
google search for that tire calculator it shows you how far off the speedo will be. If i remember correct, its not a big difference for me
Harbor Fright
2005 XT
We all grok the calculations- Q really is this: is it livable day-to-day?
2004 Forester XT MT
Running 225/45/17 and the diameter is 25". At 1.1" smaller diameter than stock, the speedo is off but not an issue. Do the quick math in head for most speed limits by adding 4.5" to speedo. The gain in torque is such that it eclipses the speedo inconvenience.
Recovering Modaholic
the gain on the ODO doesnt help though ;)
Harbor Fright
2005 XT
Thanks Martin- that's the kind of feedback I was looking for!
So is this- I am also not crazy about racking up "the extra miles"...But it will probably be worth it.
Ze flying Russian
2007 STI
Long time ago I found a good tire calculator. I liked it very much and since it was in Russian I translated it. Check it out, you might find it quite helpful too.
Click here
coming from a 4x4 and off road background I can tell you that .5" is no big deal.
most of the jeep cherokee guys I know will go up 4 or 5 whole inches in tire diameter without making any changes to gearing or speedo sender.
I went up 2 whole inches on my truck with no such changes, and find it perfectly livable.
^^^X2^^^^ Adding mileage blows! Oil changes come quicker, MAJOR SERVICE comes quicker. Your drive train is indeed driving farther than your XT!! I'm suffering from this now and can't wait to go to the proper height tire.
NahdaDamDyke said:
...the engine will top out before redline...
Huh? I'm confused. Does this imply the tach is run off the drive train somewhere past the diffs and not the engine (or crankshaft)?
(I'm not quibbling with the conclusion of staying close to OEM tire diameter; I'm just confused by this.) HPH
you will reach redline in any gear. you will just be traveling at a slower mph at any given rpm compared to the stock outer diameter. you will also reach redline faster in any gear with a shorter tire diameter.
i wouldn't worry about service intervals coming faster either. the forester doesn't know what size tires you have on the car, thats why we get speedo error. if you travel 1000 miles (according to the odometer on your dash) on the stock tire size, you actually traveled 1000 real miles. if you did the same 1000 miles on a tire that was 3% shorter overall, you'd only have actually traveled 970 real miles.
even your mpg will be off if you go by the stock odometer, and you will have to add 3% to whatever figure you come up with. but you will end up with lower than stock mpg because at any speed, your engine will be turning higher rpms.
1 - 16 of 16 Posts
