This is a 4th and 5th gear pull and it temps were in the 20s. The car threw a code in 5th. I'm wondering if this is actual boost creep or a tuning problem.
Sorry the columns don't line up.. =(
Code:
Time	Engine Speed (RPM)	Manifold Absolute Pressure (PSI)	Throttle Opening Angle (%)	Ignition Timing (°BTDC)	Vehicle Speed (MPH)	Atmospheric Pressure (PSI)	Knock Correction (°BTDC)	Fuel Injector #1 Duty (%)	Manifold Relative Pressure (PSI)	Primary Wastegate Duty Cycle (%)	Fuel Pump Duty (%)	Air/Fuel Sensor #1 (AFR)
0	3624	9.722	28.24	40	65	14.945	-4	18.55	-4.353	36.08	33.33	14.01
170	3624	14.365	42.35	34	65	14.945	2	27.06	-0.29	38.43	66.67	14.47
340	3648	17.992	54.12	25	65	14.945	5	38.14	3.482	40.78	100	12.98
510	3718	23.361	70.98	14	65	14.945	6	54.73	9.141	42.75	100	11.71
681	3776	30.035	100	9	65	14.945	4	72.49	15.671	48.24	100	11.14
851	3839	33.953	100	9	65	14.945	4	79.43	18.427	44.31	100	11.14
1021	3910	34.678	100	9	65	14.945	4	77.57	18.427	32.55	100	11.14
1191	3983	33.663	100	9	65	14.945	4	70.53	18.427	28.63	100	11.14
1362	4079	32.502	100	9	68	14.945	5	73.1	17.557	32.16	100	11.14
1532	4128	31.922	100	9	68	14.945	5	71.33	16.976	36.08	100	11.14
1702	4199	31.631	100	10	71	14.945	5	72.55	16.686	39.22	100	11.14
1872	4278	31.922	100	10	71	14.945	5	73.93	16.976	39.61	100	11.14
2043	4374	32.502	100	11	71	14.945	6	77.45	17.557	40	100	11.14
2213	4425	32.792	100	11	75	14.945	6	76.46	17.847	39.22	100	11.14
2383	4498	32.937	100	11	75	14.945	6	77.73	17.992	38.82	100	11.14
2553	4538	32.792	100	12	75	14.945	6	77.45	17.992	38.82	100	11.14
2724	4639	32.792	100	12	78	14.945	6	78.17	17.847	38.82	100	11.14
2894	4720	32.792	100	12	78	14.945	6	80.56	17.702	39.22	100	11.14
3064	4736	32.647	100	12	78	14.945	6	81.84	17.702	39.61	100	11.14
3234	4847	32.502	100	12	81	14.945	6	81.68	17.557	40.78	100	11.14
3405	4894	32.357	100	12	81	14.945	6	82.48	17.557	41.57	100	11.14
3575	4968	32.357	100	12	85	14.945	6	81.61	17.267	43.14	100	11.14
3745	5031	32.212	100	12	85	14.945	6	85.86	17.267	45.1	100	11.14
3915	5068	32.212	100	12	85	14.945	6	85.4	17.267	46.27	100	11.14
4086	5172	32.067	100	14	88	14.945	7	86.06	17.122	47.84	100	11.14
4256	5186	32.067	100	14	88	14.945	7	86.3	17.122	49.02	100	11.14
4426	5277	32.067	100	14	88	14.945	7	85.56	17.122	49.8	100	11.14
4596	5308	31.922	100	14	91	14.945	7	87.18	16.976	51.37	100	11.14
4767	5359	31.922	100	14	91	14.945	7	88.03	16.976	52.94	100	11.14
4937	5456	31.922	100	15	91	14.945	7	86.14	16.976	53.33	100	11.14
5107	5486	31.922	100	15	94	14.945	7	88.95	16.976	52.94	100	11.14
5277	5560	31.922	100	15	94	14.945	7	90.15	16.976	52.55	100	11.14
5448	5605	31.776	100	15	94	14.945	7	90.87	16.831	52.94	100	11.14
5618	5670	31.776	100	16	98	14.945	7	89.51	16.831	52.94	100	11.14
5788	5715	31.486	100	16	98	14.945	7	90.22	16.686	52.94	100	11.14
5958	5732	31.486	100	16	100	14.945	7	91.7	16.541	52.94	100	11.14
6129	5787	31.341	100	18	100	14.945	8	90.13	16.396	53.33	100	11.14
6299	5829	31.341	100	18	100	14.945	8	92.02	16.396	53.33	100	11.14
6469	5908	31.196	100	18	103	14.945	8	92	16.251	53.73	100	11.14
6639	6990	19.153	18.43	32	103	14.945	8	4.47	0.871	40.78	33.33	11.14
6810	6639	6.094	9.41	24	103	14.945	0	4.25	-9.141	0	33.33	11.94
6980	6287	4.208	9.02	24	104	14.945	0	4.02	-11.027	0	33.33	12.75
7150	5914	3.192	8.63	24	104	14.945	0	3.79	-11.753	0	33.33	13.21
7320	5597	2.757	9.8	33	104	14.945	0	7.16	-12.188	37.65	33.33	15.04
7490	5314	12.769	57.25	42	106	14.945	0	34.01	-1.451	42.75	66.67	13.67
7661	4331	20.024	100	17	106	14.945	7	58.2	6.82	52.16	100	14.01
7831	4428	30.035	100	5	105	14.945	6	84.08	15.38	52.16	100	12.63
8001	4456	34.824	100	11	105	14.945	6	91.25	18.427	38.82	100	11.37
8171	4471	35.404	100	11	105	14.945	6	85.83	18.427	27.06	100	11.14
8342	4507	34.243	100	11	106	14.945	6	83.65	18.427	22.75	100	11.14
8512	4556	33.518	100	11	106	14.945	6	77.76	18.427	20	100	11.14
8682	4561	33.227	100	11	106	14.945	6	77.83	18.282	19.61	100	11.14
8852	4605	32.937	100	12	106	14.945	6	75.64	17.992	20.78	100	11.14
9023	4613	32.792	100	12	106	14.945	6	77.75	17.992	21.18	100	11.14
9193	4655	32.792	100	12	106	14.945	6	78.44	17.847	21.57	100	11.14
9363	4653	32.647	100	12	108	14.945	6	77.42	17.847	21.96	100	11.14
9533	4687	32.647	100	13	108	14.945	7	76.99	17.702	21.96	100	11.14
9704	4740	32.647	100	13	108	14.945	7	78.87	17.702	22.75	100	11.14
9874	4733	32.502	100	13	110	14.945	7	78.76	17.557	23.53	100	11.14
10044	4785	32.502	100	13	110	14.945	7	3.06	17.557	24.71	100	11.14
10214	4954	27.133	100	17	112	14.945	7	56.01	11.753	0	100	11.94
10385	4823	28.875	78.04	15	112	14.945	7	73.06	13.784	52.55	100	13.09
10555	4771	8.851	10.59	42	112	14.945	-1	3.05	-6.82	37.65	33.33	11.83
10725	4676	4.353	9.41	24	113	14.945	0	2.99	-10.737	0	33.33	11.14
10895	4723	3.482	9.8	24	113	14.945	0	3.02	-11.608	0	33.33	11.83
11066	4671	3.192	9.8	24	113	14.945	0	2.99	-11.753	0	33.33	12.86
11236	4662	3.192	9.8	25	113	14.945	0	6.96	-11.898	37.65	33.33	14.47
11406	4643	3.192	10.98	36	113	14.945	0	7.92	-11.608	37.65	33.33	15.73
11576	4654	3.337	10.98	41	113	14.945	0	7.94	-11.608	37.65	33.33	13.67
11747	4661	4.498	15.69	44	112	14.945	0	10.94	-10.302	38.43	33.33	12.75
11917	4575	4.498	11.37	45	112	14.945	0	9.76	-10.592	38.43	33.33	13.78
12087	4576	3.337	10.2	41	111	14.945	0	2.93	-11.608	37.65	33.33	12.86
12257	4554	3.047	9.8	24	111	14.945	0	2.91	-11.898	0	33.33	14.13
12428	4526	3.047	9.8	24	111	14.945	0	2.9	-11.898	0	33.33	15.96
12598	4545	3.047	9.8	24	109	14.945	0	2.91	-11.898	0	33.33	16.31
12768	4516	3.047	9.8	24	109	14.945	0	2.89	-11.753	0	33.33	17.57
12938	4463	3.192	9.8	24	109	14.945	0	2.86	-11.753	0	33.33	20.33
13109	4426	3.337	9.8	24	109	14.945	0	2.83	-11.608	0	33.33	20.33
13279	4450	3.337	9.8	24	109	14.945	0	2.85	-11.608	0	33.33	20.33
13449	4409	3.337	9.8	24	109	14.945	0	2.82	-11.463	0	33.33	20.33
13619	4389	3.482	9.8	24	107	14.945	0	2.81	-11.463	0	33.33	20.33
13790	4361	3.482	9.8	24	107	14.945	0	2.79	-11.463	0	33.33	20.33
13960	4368	3.482	9.8	24	106	14.945	0	2.8	-11.463	0	33.33	20.33
14130	4337	3.482	9.8	24	106	14.945	0	2.78	-11.463	0	33.33	20.33
14300	4307	3.482	9.8	24	106	14.945	0	2.76	-11.463	0	33.33	20.33
14471	4273	3.627	9.8	24	104	14.945	0	2.73	-11.318	0	33.33	20.33
14641	4253	3.627	9.8	24	104	14.945	0	2.72	-11.318	0	33.33	20.33
14811	4256	3.627	9.8	24	104	14.945	0	2.72	-11.318	0	33.33	20.33
14981	4211	3.627	9.8	24	103	14.945	0	2.69	-11.318	0	33.33	20.33
So the spike is causing the CEL? It happens after I hold down the throttle in 5th for a short while.
04 XT
That I can't say. But the boost quickly peaks after a shift and settles back. Looks like a spike not creep. Creep is uncontrollable airflow through the turbine because the wastegate can't keep up. That tends to rise and continue on.
What is your target boost when you were tuned? In normal temps?
The target boost was supposed to be 18.5 psi and tuning was done at 85 degrees but my car will throw the code when below 50 degrees F.
04 XT
Does your logging software cap displayed boost at 18.427? Do you have a boost gauge to confirm?
The tuner may need to work on your wastegate DC.
Yes, the software can only read manifold pressure up to 18.4. I keep forgetting to hit the record button on my defi gauges to record the pulls but it does peak over 20psi. I logged absolute maifold pressure and atmospheric pressure so if you take the absolute manifold and subtract the atmospheric it should be the relative manifold pressure (boost reading).
I've already forwarded my logs to my tuner and he's taking a look at it.
Mexican Lorider
2004 FXT 5MT
Mine was doing the same thing. My tuner ended up turning down the WG duty cycles % from in the 50's (as yours are) to like 25% where I was geting cut. So the WG Duty %'s went from being flat to looking like a Horshoe. He also adjusted the IAT temp compensation/offset table. This way I'm still hitting target boost (and not spiking) no matter what the temps are. My target boost was 19psi yet, I was hitting 21.3 psi 4th and 5th. It seems to have done the trick as we've had quite a bit of a temp swing since Saturday. I was able to hit target boost in mid 70's temps on Saturday and only slightly spiked to 20psi at 41deg earlier tonight. Hope you get it settled soon. I know how bad it blows to hit BC in 5th. ;)
Discussion Starter · #9 ·
I got a new map in and did a few hard pulls last night. It was only 41 and not 20 something like when I did the first log but no CEL. I still saw 21 psi on my peak hold though. Just watching the boost gauge I could see it was less wild though. I'm going to put a few more miles on to let the ecu learn and then I'm going to do more logging in cooler weather. I'll have to ask my tuner what he did exactly. Something about dynamic temp compensation..
