1 - 12 of 12 Posts
1999 s/tb
Hi everybody,
When got my JDM forester has 225/55 16 W tyres on it they are road tyres as well :-( , but looking through the manual it says 215/60 16 V.
In 225 size you cant seem to get AT tyres. Is it okay to change to 215 tyres and put on AT ones. If so what would you recommend, I am finding the forester sliding..
Cheers
Loz
99 UK S-turbo
225/55 is a common upgrade as you can get more sporting tyres in that size than in 215/60 and they are the same rolling radius within 3mm.
What brand tyres have you got? If your on ice then most UK all seasons will slide!
Simon
2007 2.5 XTEn
17" Wheels
Hi everybody,
Cheers
Loz
My 2007 XT has 17" wheels with 215/55/17 tyres but some of the tyres I am considering are only available in 215/60/17 would it be ok to fit the 60 aspect ones? I realize the speedo will be slightly out but can anyone see any snags
Regards
none none
That size (215/60/17) "should" fit as its between the size of a 215/65/16 and 215/70/16, so it should clear the suspension. The 65 definitely fits on 03-08 foresters, 70 will usually fit. If you're lowered at all they'll likely rub. The 215/60/17 should clear everything (some might not though, especially if they have an offroad or beefier tread)
Yorkshireman, not a DUDE!
2011 Mitsi RA Sportback SST
Can I also ask a tyre question (Hope you don't mind Loz !).
T/tb has 225/50/17 's on at the moment, not exactly a wide market choice of supplier.
What would be an alternative 17" size that would give more market choice ? Nothing fatter as these are quite hefty ones !
Does this make sense ?
Brian
99 UK S-turbo
Speedo will be a long way out due to the extra 1/2" of wheel, may also foul as its a larger radius, very bad idea I think!
Simon
G
Brian
215/55/17 is a good choice and a perfect fit too!
You can also get Vredestein sportracs in this size :icon_biggrin:
none none
Simon
The speedo actually over-reads by quite a bit stock (at least on 03+). On mine the speedo is perfectly dead on with 215/65/16, its almost like they thought they were going to use that size stock on the SG and then changed their minds. Anything taller than 215/60/16 however will not fit all that well if lowered.
Agree with AP, 215/55/17 is a good bet, I'm running 225/50/17 for summers, but only because the 235/50/17 was out of stock and actually like the 225/50 size, seems to be a good match to a moderately lowered/modded forester (running ze912, which isn't my favorite, but is a decent dry/wet tire).
1 - 12 of 12 Posts
