1 - 20 of 109 Posts
2012 GTI DSG 6-speed
Just finished up my version of the SG mesh grill. No body putty is required just dremel cutting time and finishing. If one were careful I would think it could be done without repainting. Cut line was determined by existing bezel screw landings(top), crossbars (side) and curve (bottom). It's too cold to wash the car right now (28 degrees F) so please excuse the dirt. :)
edit: updated to "without repainting", and cut line information
edit: washed car, added new images and thumbnails.
Ze flying Russian
2007 STI
What kind of mesh is that? Did you get it at Home Depot? How do you attach the mesh to the grill?
Can you spell GREAT JOB? :)
Casper reincarnated
Very nice!
I like your handiwork and the mesh itself TAGXT04
Thanks for the kind words. I used eBay aluminum black mesh. The space is quite large so I picked up a piece 8" x 36". The paint is Duplicolor T177 Gunmetal.
The sides and top are held in place with the same screws that secure the chrome bezel. The bottom connections are made with small zip ties looped through the lower snaps where the chrome bezel also mounts. I also found that a rubber bushing for a faucet makes a nice "nut" to hold the badge in place.
2019 Forester Touring
Darn nice job, man.....
I got a grill off eBay for Christams so I'm getting ready to start the custom work on it myself.......
I really like your result.......
Steve
2016 2.5i Premium CVT
Any ideas what we could ask for if we were to search locally (eg Homedepot) for the mesh? That's an awesome looking grill!
Discussion Starter · #9 ·
I tried Lowes and the Depot but the pre-cut mesh is too small as is gutter mesh. Someone mentioned "bulk" mesh that might be used for stucco work but I never asked.
See the eBay mesh that I used here:
http://cgi.ebay.com/ebaymotors/Univ...cmdZViewItemQQcategoryZ33645QQitemZ8029015731
Discussion Starter · #11 ·
sirwilliam said:
Wow, I was so impressed that I ordered mine "Pay Now" for $25 bux shipped.
Just curious...it looks like you are holding it on at the top by screws but how are you holding it on at the bottom?
See the last picture with the small black zip ties looped through the snap connections.
2008 SG Model D
Thanks...got my zipties and ziptie gun waiting for me at home :wink:
sweet grille TAG-
i'd like to check that out in person sometime- Hopefully some meets will be set up in PGH this year-
good work,
_d
Discussion Starter · #15 ·
GarageXTi said:
sweet grille TAG-
good work,
_d
The local Subaru guys (mostly from nasioc) get together the 1st Wednesday of the month at Quaker Steak and Lube (QSL) in Robinson. I'm sure I'll be there on February 1.
Tom
2008 SG Model D
Well,
Finally got my grill mesh in. Got home last night and started to do what I think will be my final grill mod. Well, I got my dewalt highrpm circle cutter tool (like a dremel on steriods or a viking dremel) set w/ a cutting blade but it just melted the plastic. It doesn't have a speed adjustment...it is just set from the factory at ludacris speed.
So what did I do, I took out my utility knife...you heard me right...and I went to work. Well I got most of it done last night...got up this morning and finished w/ the cutting of the utility knife. It was a little rough around the edges so I sanded it down. I put on the new mesh and it looks a LOT better. Haven't decided on the final front badge and still need to get a couple final coats of spray paint on the trim but it is on the XT and looking sweet!
I will post pics when I have time...but moving the mesh forward really has a night and day affect on how good it looks. :wink:
Recovering Modaholic
got mine done over the weekend, looks super!!!! thanks for the tips! I'm gonna get pics as soon as my new emblem gets here :D
I used masking tape to mark my cutting line and dremmeled (sp?) away! I went through about a dozen cutting wheels, including the ones used for cutting the wire mesh ($30 APC mesh insert from pep boys...damn rip off!)
on a side not, a metal supply company locally has steel mesh sheets for 1.98 /lb and they come in all diff designs, honecomp, round, square, diamond shape. they were closed this weekend and I was just anxious to get it done so I bought the pep boys aluminum insert.
edit tool not working :(
edit:
the dremel cutting wheels melted the plastic while cutting but i was able to break the melted parts off with my thumb. I did this by pushing them towards the cut side, not the finish side, doing this prevented any need to repaint. it looks totally custom the only painting I had to do was the mesh insert.
Discussion Starter · #19 ·
edit:
Good tip about the masking tape. I knew someone could do it without repainting! Looking forward to some pics.
05 XTi FMIC
I just did a visual to see how to get the grill off. Any words of advice before I start trying to get the grill free for this mod?
Thx in advance
1 - 20 of 109 Posts
