2021 Limited
Not sure if this is in the right forum, but here goes:
I have about 16,300 on my 09 Limited. At I recently had the tires rotated ( I was a little late -- I rotated them last at 7600) and found that the car started drifting to the right. I talked to my mechanic who said that it probably wasn't the alignment, but could be a bad tire.
He rotated them back and the problem is solved for now, but he couldn't see any problems with the tires. So, now what do I do? If I can't rotate them, they will wear unevenly. If I do rotate them, the car will pull to the right, and the tires will wear unevenly.
Suggestions? Thanks, all.
03 x
tire pull does happen and the way to conferm this is put them back on the front but reverse the sides so right tire on the left and vice versa. see if the pull changes directions. if it does it should be covered under the tire manufacturers warrenty
2021 Limited
Thanks -- I'll give that a try. Probably will go to the dealer so they can see for themselves. I suspect this will be a bit of an arm-wrestling match to get them to make it a warranty issue.
2008 Forester X Premium 5MT
Tire warranty is separate from the vehicle warranty. You can go to any tire dealer that deals in the brand on the car. Check the additional tire warranty card, it should be with the owners manual.
