1 - 2 of 2 Posts
13 Forester XT 4EAT
So I installed new springs and struts. I stripped a front camber nut on re-installation so I put a new camber nut/bolt combo in there. Needless to say I forgot to mark the bolts and just put the camber bolt and nut on. I have sub frame lock out bolts I'm going to try and install tonight and then was planning on bringing my car in to have new tires mounted/balanced and an alignment done.
I'm worried about the camber bolt I installed, it may be close to stock settings or could be way off. I'm assuming they will correct all the settings when the alignment is done? Am I overthinking this?
1 - 2 of 2 Posts
