1998 Forester S 4EAT
As of right now, I am doing some research on my foresters electrical system so I can wire in a new keyless/alarm system. The new alarm system requires a door trigger. What if I were to wire the door trigger to the domelight because all of the doors trigger the light to go on.
Would this be a good idea or should I just stick to wiring it to the jam switch?
1998 S 6MT!
Hey, I just recently installed a python (Viper) 991 remote start in my ’98 forester.
What I used for my door trigger was yellow wire in the keyless entry stock wiring harness and I used the same wire for the domelight supervision. BUT BUT you need to either diode isolate the 2 wires or use a relay to isolate them. I used trial and error and found that both worked equally well but the diode saved space and wiring.
PM if you have any questions, I learned a lot installing mine..
And below is the wiring colors that helped!
1998-1999Â*SubaruÂ*ForesterÂ*Vehicle Wiring Chart and Diagram
2007 Forester Sports XT Manual
Unless you're wiring in a remote start, those alarms are generally more trouble than they are worth.
